Export dwg with project north
bozandilistan
bozandilistan
Hi
I want to export floor plans as project north and shared. But when i follow export setup> unit coordinates> shared, it exported with true north, but my floor plan's orientation set yp to project north actually. what should i do?
export the sheet - NOT the view
chrisplyler
Maybe DON'T set up the export using shared coordinates?
@bozandilistan
I think what you got with the settings is obvious.  Not sure why you expected otherwise.
If you want to show the Project Base Point (or Survey Point, or Origin Point) as 0,0,0 in DWG, then place a Datum element or symbol with a line to indicate the true north at such point.  Export the view oriented to Project North, using Project internal option.  Open it and move everything from the Datum point to 0,0,0.
