export dwg - links in different position
mairh_tsek
mairh_tsek
Hello all,
When I export a .dwg file from Revit and unselect the option 'Export views on sheets and links as external references'
all the links that I had in Revit come in the same position in autoCAD. but the file references dialog in autoCAD  is empty.
As I want to have also the file references in autocad, in Revit I check the option ' Export views on sheets and links as external references', the problem is that after the exporting some linked files come in different position in autocad. I tried both make the export with the shared point or with the project base point.
Any idea how can I have in autoCAD all the files in the same place ?
Thank you in advance!
mariano_biagioli
Export with the option 'Export views on sheets and links as external references' and then use de comand Xref in AutoCAD to link (attach) all the files you have exported.
Select coodinates position  x=0 y=0 z=0
