Export dwg in grey colour
7 REPLIES 7
Message 1 of 8
mairh_tsek
1070 Views, 7 Replies
Hello all,
I have a project with different phases in which I have linked some rvt models. I want to export a dwg having all the elements in grey colour.
How can I do it?
Thank you in advance!
7 REPLIES 7
Message 2 of 8
Have you tried selecting everything and then right click > override graphics in view > by element and then change colours and patterns as required.
AJ.
Message 3 of 8
Yes but nothing happens..
Thank you
Message 4 of 8
in reply to: mairh_tsek
You can modify the export settings for CAD exports and set the colours for the layers.  To do this, go to File - Export - Options - Modify DWG Export settings.  Set the colours to grey.
Message 5 of 8
hmunsell
in your export, change your Export Layer Options:
Howard Munsell
Message 6 of 8
mairh_tsek
in reply to: hmunsell
ok I will try it.
And if I want to export exaclty the colours that I have in the view in Revit, what I should do ?
Thank you !
Message 7 of 8
hmunsell
edit the export table to reflect what colors your using in Reivt.
Howard Munsell
Message 8 of 8
