Export design options as separate files
arian.saeedfar
Alumni Alumni
arian.saeedfar
I have a question about design options. Is there any way that I can export each design option as a separate file?
Sahay_R
Open the option you want to copy.
Go to a 3D view and window select everything. (You'll get all the elements in the option.
Group the selection.
Save the group out as a separate rvt file.
You can then ungroup all the elements if you choose or leave it as is.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Viveka_CD
Hi @arian.saeedfar
I see that you are a new member! Welcome and thanks for posting on the forum! Smiley Happy
Are your design options specific to one model or are you thinking of using them in multiple projects?
You can try grouping them and saving as individual options as suggested by @Sahay_R, or toggle between visibility graphics to hide the rest.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
arian.saeedfar
Rina,
Thanks a lot for the help. It works perfectly fine.
Best,
Arian
arian.saeedfar
Viveka,
Thank you for your welcome message. Yes, this is the first time I'm using Revit forum. And I appreciate your solution. It worked very well.
Best,
Arian
Viveka_CD
Hi @arian.saeedfar sounds good! I'm glad to hear that!
Please feel free to post any other questions and this community is happy to help!
dwhitingRBKY9
@Viveka_CD Is there a way of exporting multiple design options into one 3D model that can be turned on and off just as they can in the model with Viz/Graphics? For instance, I am looking to upload a model to the Autodesk Viewer, and would love for our clients to be able to turn design options on/off for viewing. Is this possible?
