Excel Fire Protection
Is it possible to read out an Excel spreadsheet in Revit with all wall lengths, which then shows me if e.g. at 40 meters are reached, a fire wall is required.
bimscape
On the face of it, it sounds like you need a Wall Scheule, and a claucluated Value parameter, and Conditional Formatting (to highlight) the results.
It may not be quite a simple as that- depending on your model: For example- say you have a really long, linear building which has a couple of walls that run the full lenght (creating a central corridor)- they will have cross walls hitting them, so breaking up their total length- but Revit will just tell you the total length of each Wall instance.
Hope that makes sense?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
