Example Dynamo Scripts
wr.marshall
Advisor Advisor
wr.marshall
Add Example Dynamo Scripts that are common/frequently used as part of a typical Revit install.
There should be well documented notes within the script as to what tool does, how various elements work, how a particular node benefits the script etc.... This will help new users just getting into Dynamo scripting understand how to create scripts
Some Examples may be:
  • Rotate all Columns on their own individual axis
  • Extend Truss(Howe Truss) to suit as a wall is moved back and forth
  • Get Coordinates and add this to a schedule
Probably many others. If anyone got suggestions please feel free to comment.
kimberly_fuhrman-jones
Hi, @wr.marshall ,
There are several sample Dynamo scripts included in the Dynamo Player that is a part of Revit. In each script, there is an Edit button (pencil) that will open the script in Dynamo, with detailed explanations of the script. Let me know if this is what you are looking for!
-Kimberly
Kimberly Fuhrman-Jones
Revit Community Manager
wr.marshall
That's exactly sort of thing I was thinking. Probably moved to arch forum and mark as solved.
Only thing to add to the above is the location of the files which looks like:
C:\ProgramData\Autodesk\RVT 2024\Dynamo\samples\en-GB\Revit\DynamoPlayer-6
If anyone was wondering where they are stored
Thank you, @wr.marshall ! Moved from the Revit Ideas.
