Creating Fill pattern in Family
sudip.bhuniaMT2GQ
Message 1 of 12
sudip.bhuniaMT2GQ
I have TWO issues related to Hatches-
First one-
I have created a pat file (as a Drafting Hatch_pat file),
While linked that shows this error. I am doing it in Detail family.
Second one-
After assigning a hatch pattern in the Ceiling (Surface & Cut), in the section, the cut hatch pattern not showing.
Need help.
Sudip
Replies (11)
Message 2 of 12
kostask_oionei
1. Does your .pat file begin with:
*Pattern_name, Pattern Description
;%TYPE=DRAFTING
2. Check the Pattern scale.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Message 3 of 12
sudip.bhuniaMT2GQ
Hi kostask_oionei,
 Thank you for your reply.
I created the hatch in Revit (By pyrevit)not in CAD and you can see the Name in the First image. The scale of hatch is 1:1.
and have you checked the issue that is the section hatch issue?
Waiting for your reply.
 Sudip
Message 4 of 12
kostask_oionei
Can you post the .pat file?
Kostas Kouris
Message 5 of 12
sudip.bhuniaMT2GQ
Please find the pat file.
Message 6 of 12
kostask_oionei
I can not see the pat file.
Kostas Kouris
Message 7 of 12
sudip.bhuniaMT2GQ
Hi ,
By mistake, I hit up solution button. it is not solved.
Do you have any updates on my second issue?
Sudip
Message 8 of 12
kostask_oionei
--CORRECTED POST--
Sorry, I can't find the pat file
I would like to try the pattern, that's why I ask you for the pat file.
It is hard to say without testing.
Kostas Kouris
Message 9 of 12
sudip.bhuniaMT2GQ
Message 10 of 12
kostask_oionei
Where do you attached the file? Because I can't find it here.
Kostas Kouris
Message 11 of 12
Pattycake_Kyle
@sudip.bhuniaMT2GQ  FYI. I believe the forum blocks .PAT file extensions. If uploading, change it to a .txt and it should upload just fine. (if I'm remembering correctly --- haven't tried to post one in awhile).
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 12 of 12
sudip.bhuniaMT2GQ
 Now I uploaded the pat file(Changed to Txt file).
Please have a look.
Sudip
