Error with corrugated metal curtain panel
dkapisiz
Observer Observer
dkapisiz
Observer
Observer
I created a curtain wall panel that mimics corrugated metal, the distance I had made it in curtain wall panel pattern, 150mm wide.
When I go to change the properties of the curtain wall and start drawing it out, I get this error code. How do I fix this so it repeats? I watched Balkan Architect tutorial and did exactly as same but isn't working.
Tom_Kunsman
Based on that error, it seems like you have more than 200 curtain wall mullions (grid lines) - you cannot have that many in one wall segment. Might also be due to the very small corrugations you are trying to model.
dkapisiz
Observer
Observer
I thought Curtain Wall Exterior Glazing has no curtain wall mullions
though? I tried using an empty Curtain Wall glaze but still didn't do the
trick
Post both the RVT and RFA here.
vitorbortoncello
You can manage to do it another way. Create a void sweep and add it to a basic wall.
it is invisible, because it is a void:
Just create similar (CS) and adjust in your wall
if you want to change the profile open the family, it looks like this:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @dkapisiz
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
