Floor core boundary alignment problem
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
46b002b9363c
931 Aufrufe, 13 Antworten
So I have two types of floor, 1- 200mm concrete as core boundary, 10mm tile as finish. 2- the second floor is same as first but with added 5mm of carpet above the tile. if I create two floors next to each other with each floor type on the same level; their top will align, meaning that one of them will have 5mm concrete below the other when in reality the core boundary (the 200mm concrete) should be aligned not the finishes. And yes Ik i can do it with offsets or align tool manually, but I'm looking for a better option. picture
13 ANTWORTEN 13
Nachricht 2 von 14
ridantuo
als Antwort auf: 46b002b9363c
Canät really say anything else than model it as it would be built.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Nachricht 3 von 14
46b002b9363c
als Antwort auf: ridantuo
well im trying to model as it should be built, clearly im having a problem. Also im not saying the computer or the software is the problem. unhelpful overall.
Nachricht 4 von 14
jay_colcombe
Where the boundaries will differ you should model them individually.  Where a Slab may be under walls this should be a Structural Floor build-up and for Finishes which may be inside walls they have a different Floor for the Finishes and build them up this way with offsets from the level to stack them on top of each other to get the overall desired build up
There is no one click solution for this you either use offsets from Level or the Align Tool to match the individual elements to each other and you can lock them together for future reference so they move as one.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 5 von 14
There is no better option.  Period.
Nachricht 6 von 14
SteveKStafford
Model the structural slab(s) separate from finishes. Model finish floors separately from structure, and other finish floors, adjust their offset "up" so they sit on top of the structural slab and disable "room bounding" for each.
Steve Stafford
Nachricht 7 von 14
Do you want the finished align or the core align?  Practically, it is one floor and you add a carpet over a portion of the area. No?
Nachricht 8 von 14
46b002b9363c
als Antwort auf: ToanDN
I want the core to align. Yes in same cases you have a small carpet somewhere in the room but yk its the idea of it; maybe not carpet, for example where I live for bathroom and toilets; they give it like 10mm of depth so liquids (water) stay inside the bathroom.
Nachricht 9 von 14
46b002b9363c
als Antwort auf: SteveKStafford
I have thought of this but then if I do the offset I can just do the offset to with complete floor types (not just structural, floors that have finishes too) otherwise if you think your way is a better approach please do tell me the reason I'd love to adopt some rules into my workflow.
Nachricht 10 von 14
SteveKStafford
My primary motivation is it imitates life, we don't build little chunks of structural floors with different finishes applied. We build a structural floor and then add finishes on top of that. Also the finishes don't usually go under walls or cabinets. So the finish floors make it easier to just put down the finish where it will really be needed.
Also separate finish floors make it easier to schedule them. Tagging is already easy but you can show plans without finish floors and with a bit easier using Filter that looks for floors that have a prefix of Finish- for example. It's important to disable the room bounding setting for finish floors if you're going to share your model with other Revit using disciplines.
Steve Stafford
Nachricht 11 von 14
46b002b9363c
You got a great point actually. I'll do it this way from now on. Thanks for the explanation.
Nachricht 12 von 14
Then model it as one floor and add a thin carpet finish floor with 5mm offset from level on top.  You can model finish floors using roof above structural floor because roof aligns at the bottom, no need to offset from level.
Nachricht 13 von 14
46b002b9363c
Hi, sorry to bother you again; I did what you said, made specific floor types for the finish (13mm tile) and specific floor type for the structural floor (200mm concrete) how ever revit doesn't allow floor types with core boundary layer so what I did for the 13mm tile is I set it as core boundary; is this the right way? if not please let me know
Nachricht 14 von 14
jay_colcombe
yes, although it is a floor finish it can still be set with the core boundary
Jay Colcombe
