ERROR WHILE CREATING WIDTH PARAMETER FORMULA IN REVIT26
saabithmhd
saabithmhd
Tried to build Room_tag in Revit 2026.
The [length] calculated parameters to label (Formula : (Perimeter + sqrt(Perimeter ^ 2 - 16 * Area)) / 4) worked.
But when it comes to [width] calculated parameters to label (Formula : Area / Length) did not work.
It is showing:
The following is not a valid parameter: Length
Note that parameter names are case sensitive.
Mike.FORM
The length parameter supposed to be all lowercase as in "length" not "Length" how your formula has it written.
That's specifically what the error is stating.
saabithmhd
TRIED EVERY TYPES : LOCERCASE, UPPERCASE, MIXED NO USE
Mike.FORM
Have you copy + pasted the length parameter name?
You do not have Length parameter in your available parameters.  Add Length parameter before creating the calculated formula.
RLY_15
If you're using multiple calculated parameters, you have to finish creating the first one before the next one refers to it. In your screenshot, you started with a blank label; you don't have the calculated parameter 'length' defined anywhere.
Also, when you create a calculated parameter in a Label, it only exists in that specific Label.
