Error: "A serious error has occurred" when offsetting a wall in Revit
While using the copy or offset command following error dialogue box appears.
Can someone help me on this issue, I have already tried reinstalling the software.
syman2000
Did you purge, audit and fix errors in the project? Does this appear when you start new project and attempt the same method?
Hi, Just opened a new project by using Imperial Architectural template, drawn a simple wall and use the copy button, and the error message popsup.
syman2000
Sounds like you may need to reinstall Revit. Also make sure you have the lastest update to mitigate these issues.
Hi, have you got any solution for the problem, i am facing the same issue
