Dear all
Please see below image.
When I tried to modify mass model, I failed with above message.
Should I divide to new mass family?
Please let me know the reason and solution.
Thanks and Regards,
Solved by FGPerraudin. Go to Solution.
Hi @lygking,
Yes unfortunately the message is pretty clear...
But I am quite surprised you have managed to reach the maximum number of edges!!!
If I were you, befor thinking of separating your model into different bits, I would try to simplify my geometry (use curves instead of many segments, avoid too many cuts, etc....). Have you for example used imported geometry? (in this case, delete the import, purge your mass......) What workflow have you used and How did you get to this amount of edges?
If you can share family, would happily have a look for you!
François-gabriel
Francois-Gabriel Perraudin
BIM management and coaching
