Error message while trying to transfer View Templates from a project to another.
LauraJohanssonV34EQ
Message 1 of 21
LauraJohanssonV34EQ
I have two projects and I need to transfer the View templates from Project A to Project B, however every time I try I get the following error message: "The project standards cannot be transferred" see snippet
This only happens when I try to transfer the View template, anything else, filled regions, text etc, transfers without a problem.
I also tried to open up a new project and transfer the project standards into a blank project and I still get this error.
I am using Revit 2018 MEP
Thank you kindly!
Replies (20)
Message 2 of 21
ennujozlagam
you can refer to these LINK and LINK and see if helps. thanks
Message 3 of 21
LauraJohanssonV34EQ
@ennujozlagam both links are the same.
Revit will not even run the command, so the journal will not have that detail.
I have looked through the journal but without knowing what I am looking for it is hard to know where the error is.
Message 4 of 21
ennujozlagam
okay sorry about that? try to check your file that you are going to transfer which may have a Level or View Range setting checked and view template assign change to none and see if helps. thanks
Message 5 of 21
LauraJohanssonV34EQ
Not sure I am following you....Check in the view template if there is a level checked? In the View range?
Cheers!
Message 6 of 21
ennujozlagam
open you file and/0r select items to copy uncheck or check only those you need?
Message 7 of 21
LauraJohanssonV34EQ
@ennujozlagam I have checked only the ones I need, and even tried different combinations of things checked unchecked and unless I have all checked it will not allow me to transfer project standards. It's like a bug or something
Message 8 of 21
Do you see "Illegal duplicate mapping detected" in the Journal File?
Message 9 of 21
LauraJohanssonV34EQ
@barthbradley, No,  I searched for it and the journal does not contain it.
Message 10 of 21
Can you transfer the VT into ANY Project?
Message 11 of 21
LauraJohanssonV34EQ
@barthbradley No, I tried a blank project and the project that I am in and it will not. I tried transferring from other projects into my project and it worked, so it is something in the project that I am transferring from. I can uncheck the first 21 boxes before I start getting the error message, but I haven't been able to pinpoint what works and what doesn't yet.
Message 12 of 21
Got me stumped. Happy to help you troubleshoot if you want to share the Project with the VTs?
Message 13 of 21
LauraJohanssonV34EQ
I have found in the journal where the project transfer command occurs, but there is no error id number attached there, just tells me that Revit did not execute it. Unless this is it:
1:< DBG_INFO: Bad argument: preTouch was called with wrong pElemPtr [19666403]:
Message 14 of 21
That's probably it.  Delete whatever is associated with that ID and see if that corrects the issue.  Stand away from the computer just in case though .  😉
Message 15 of 21
LauraJohanssonV34EQ
It was a level, so I deleted the level and the issue is still there 😞 I will just continue manually copying over and setting up filters.
Message 16 of 21
Bummer. Ain't troubleshooting a blast?
Not.
Message 17 of 21
LauraJohanssonV34EQ
@barthbradley  Sometimes doing it yourself, instead of relying on Revit, is the faster solution 😞 what a bummer!
Message 18 of 21
syman2000
view template may sometimes include shared parameter that don't exist in newer project which may cause issue with the transfer. So you may want to include project parameters along with view template. i was wonder if you can upload the sample file for us to troubleshoot.
Message 19 of 21
LauraJohanssonV34EQ
@syman2000 I have tried that, I still get the error. So far I have been able to untick the first 21 boxes from the top and all boxes before View Template from the bottom without getting the error. So the error must be within that range of elements.
Message 20 of 21
syman2000
Upload the sample file so we can dig in the issue.
