Error message while creating material
Message 1 of 24
I keep getting this message "unrecoverable error has occurred" while creating material. Am using revit 18 and 17
Replies (23)
Message 2 of 24
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
 Try one or more of the following steps:
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Message 3 of 24
angelica.rodriguez.3d
It might be a known error with the version of revit. Try getting the latest service pack or do a Audit to your file to make sure any corrupted data is deleted.
Message 4 of 24
I have download and install the update but still thesame. There are no corrupt files.
Message 5 of 24
Viveka_CD
Hi @Anonymous
If you have Revit 2018, confirm that 2018.2 in the latest update. I hope you have that installed from your Autodesk Dekstop App.
Did you try disabling Hardware accelartion and see if that helped?
Go to "R" (Application Button) -> Options -> Graphics -> Hardware Acceleration -> Uncheck the box and click OK.
Please try to reinstall the Material Libraries by following the procedures on  How to uninstall and reinstall Autodesk Material Library.
Let me know if this helps reosolve the ssue.
Message 6 of 24
Thanks.Have carried  out all the listed possible solutions but am still getting the error message
Message 7 of 24
Viveka_CD
Hi @Anonymous
Please share your journal file to investigate further.
Message 8 of 24
Attached is the screen short of the error message. Thanks
Message 9 of 24
thanks for the response, have done all listed solution, but still getting the error message.
Message 10 of 24
Sahay_R
Does the Project give you the same error on a different machine?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 11 of 24
Have not try that. But what if it doesn't, what could be wrong with my laptop pls
Message 12 of 24
Viveka_CD
Hi @Anonymous
Can you please share your journal to investigate the issue?
Message 13 of 24
Here is the attachment
Message 14 of 24
Sahay_R
@Anonymous One of the first steps to take in troubleshooting is to replicate the problem on another machine. Can you share the file?
Rina Sahay
Message 15 of 24
here is one of my files though i get the error message
Message 16 of 24
Viveka_CD
Hi @Anonymous
Unfortunately, I did not get your attachment.
Please see image below - scroll down when you reply to this post and click choose the file in attachments below
Let me know if you are able to attach the file or I can send you a private upload folder.
Looking forward to your reply update.
Message 17 of 24
Viveka_CD
Hi @Anonymous
I'm just checking back to see if you were able to upload the file.
I've also shared a private upload folder with you. Please let me know if are able to access this folder.
Looking forward to your reply update!
Message 18 of 24
Journal uploaded Thanks
Message 19 of 24
Viveka_CD
Hi @Anonymous
Thanks for uploading your Revit file.
I will require your journal file as well. Please upload and let me know when you are done.
Message 20 of 24
Viveka_CD
Hi @Anonymous
I did not see your journal file in the shared folder. Please try uploading again and let me know. I can better investigate the cause of this behavior with a journal.
However, I was able to test your Revit model, and I was able to apply materials. Revit does not crash.So the model is all good.
I was also able to find your Customer error reporting details (from the form you filled out when the crash occurred)
Can you try the below for me and see if this helps resolve the issue?
     1.Open Windows Explorer and browse to the folder with the name of your Revit installation:
  • Windows 7/8/10: C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit
    Note:  The AppData folder is a hidden folder. To show hidden folders, you will need to enable 'Show hidden files and folders from Windows Explorer.
    To do this in Windows 7, follow the steps in the following article:
    Show hidden files
  • 2.Within this folder, you should find a folder named "Autodesk Revit %PRODUCT VERSION%" rename this "Autodesk Revit %PRODUCT VERSION%_Backup"
  • 3.Start Revit and a new folder should be created.  If a file was corrupted within the folder, Revit may be able to then start with a new initialized user folder
