Error creating a panel of curtain wall
Hi!
I've created a family of panel of curtain wall for an specific design, imported to the proyect, but when i try to modify the curtain wall and choose my design, an error appears. Translated to english is something similar to " the parameter of type can't point/handle the type itself".
The wall has the same measurements than the family. Related to this, the family weights 3mb, I don't know if it's too much for a family.
Does someone know the reason?
Thanks in advance.
Regards
Javier
I attach a couple of screenshotfamilyfamilyerrorerror
Ilic.Andrej
I think this is really heavy stuff for the curtain wall to compute. All those tiny voids- its a lot. Try this: open the family and copy the geometry to clipboard. Paste it to another family which is made using a different family template (start with generic model family template). So, create a generic model but with fixed dimensions (not parametric). Load that to project and see if it works.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
It works!
Yep, you were right, the model has to much geometry.
Thanks you!
