Error analytical model edge cannot have a length of zero
Hello Autodesk comunity,
I've got an error message i cant explain. See picture below.
Does anyone know how to solve?
Hope to hear.
B.R.,
PPF
Sounds like you are not using analytical, otherwise this would make sense to you. Disregard. Turn off analytical model.
Thank you, but that was what i thought also indeed. But this not works. i should of explained it better in my question.
If you really want to dig into it, click "expand" to find out what elements are affected. All that message is telling you is that the problem exists. Click "expand" and it may list every single element in your project. ARRGH! Then what?  Do you get where I coming from?
RDAOU
@Anonymous Hi
It says "Error Cannot be Ignored" and it means it...Ignoring the error will not make it go away unless you don't want to move on forward with whatever you were trying to do there...so you can start with what were you trying to do when you received that error?...and that element you were modifying what is it constrained to
