Equipment Tag with Visibility Settings Linked to Formula
Hello!
Having a bit of difficulty trying to create this equipment tag with some special parameters.
The tag itself displays text linked to a shared parameter within the equipment family. I also want the tag to display a certain color filled region depending on what text is being displayed. There are three colors to display.
So
My current thinking is to assign each text instance a numerical value from another shared parameter within the equipment family since formulas don't work with text; 1=orange fill, 2= green fill, 3=grey fill. The tag then has three type visibility yes/no parameters for each fill. The formulas for those visibility settings is what I am struggling with.
The formula sounds easy enough; IF(Number = 1, Visible, Not Visible) Questions are; how do I link the integer value I assigned for each fill in the visibility setting for that fill and/or the tag itself? What exactly would the formula be to get these to display properly?
I hope this makes sense, happy to answer any questions and further clarify. Thanks in advance!
Sahay_R
A non-formula approach here - bear with me. Add your numerical value as a text parameter or at least a Comment. Apply filters to your view template. Filter for the text parameter / Comment, as the case may be.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
@Anonymous
You cannot link a parameter value in the host family to a visibility parameter in the the family.  But you can link the parameter value in the host family to a text parameter in the tag family.  For example: you can create a label in the tag family with a formula to show letter "A" if a value of a parameter in the host family = "a", else it will be blank.
Now, if you change the label type to red color, change letter A to a special symbol in the Windows character map, then you can have something similar to a colored filled region.  Create different labels and types for different colors you need then you can have what you need.
See example:
Viveka_CD
Hi @Anonymous
It's been a while and I wanted to check back with you on this post. How is everything working out?
Are you seeking more assistance from the community?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Hello!
I haven't been able to hop back on this little project since I've posted my orginal questions. I will be back on it at some point, though bigger things to work on in the meantime. Thanks for your reply.
-Elliott
