Enlarge model in sheet
Message 1 of 16
How cna enlarge the model in sheet?
The house is littler than others in photograph.
Can find .rvt file here.
https://forums.autodesk.com/t5/revit-architecture-forum/uniform-texture-of-roof-of-skylight/m-p/9321...
Thank's
Accepted solutions (3)
Replies (15)
Message 2 of 16
MostafaElashmawy
change the scale of the view.
Mostafa Elashmawy
Message 3 of 16
@MostafaElashmawy  can move between 1:100 and 1:200?
Message 4 of 16
MostafaElashmawy
Choose custom, then add whatever scale you want.
Mostafa Elashmawy
Message 5 of 16
MostafaElashmawy
check video
https://knowledge.autodesk.com/community/screencast/12866e97-94e2-41dc-87af-35a692d4c9da
Mostafa Elashmawy
Message 6 of 16
Just Zoom in on the House in the View.
Message 7 of 16
If it is a camera view, then:
1. Select the view on sheet and turn on Crop region
2. Click Size Crop from Ribbon
3. Choose Scale, NOT Field of View
4. Change Width and/or Height
By the way, the perspective of that model and the surrounding don't match at all.
Message 8 of 16
MostafaElashmawy
Let me know if above helped or did I misunderstood you?
Mostafa Elashmawy
Message 9 of 16
@MostafaElashmawy  think it's clear.
I delivered the project.
When I will read I will answer.
Thank's so much!
Message 10 of 16
@ToanDN
Do not undrestand.
Where is scale?
Thank's
Message 11 of 16
@barthbradley  do not undrestand?
In 3D view have to zoom?
In the sheet doesn't change nothing.
Message 12 of 16
Corsten.Au
Hello
Try to use two different Views on the sheet.. ( overlapping two different views on same sheet )
1. for Background ( this can be a plan, callout, drafting view with the JPG you need )
2. 3D view..
adjust both views as per your requirement..
Cheers.
Corsten
Building Designer
Message 13 of 16
@Corsten.Au  how can I to overlap two figure?
IO can do if I render the house.
With a unreal view I don't know how can do.
Thank's
Message 14 of 16
You're using a 3D view for this.  Rather use the camera to create a perspective view.  You then have the option to use the Field of view setting.
Look at the background picture in your image.  Estimate where the photo is taken from and place your camera there.  You can then start adjusting the FOV or scale so that your image starts to look correct.  You cannot use a normal 3D view for this.  Also look at the shadows in the image to estimate the time of day.  Set this in so that your view starts to look more realistic.
Message 15 of 16
@Anonymous  a screenshot please.
Message 16 of 16
See attached images.
