Energy modeling using spaces don’t get results.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am using Revit for energy modeling and in for that I created spaces and thermal zones in my model, because I wanted to do the modeling using spaces or zones. I selected this option in mode in the energy parameters, and in building data I assigned a building type for my model, so all characteristics such as lighting, miscellaneous loads, outdoor air are by type and not by space. For the material thermal properties, I used the conceptual and schematic type, and I didn’t select detailed elements.
Then I used the system analysis to run the model, but I couldn’t get any result for HVAC systems loads nor for annual simulations (it says in the “zone load summary” that there are not zones found for the HVAC systems loads). I tried to select different space types for the spaces instead of having all properties by building type, but I also couldn’t’ have a result.
However, when I assign in the mode option conceptual masses and building elements, I could get results. I wonder what I have been doing wrong for not having results using spaces and zones option. I appreciate any help about it.
