Energy Analysis Won't Run
huick2
Message 1 of 19
huick2
I have my fully created 3D model, Which has conceptual mass and the mass floor. Also I created the energy model of the mass, but when I run "Create Energy model" It keeps telling me
"There are no visible Masses in the current View.
Either create a mass or adjust the visibility of an existing Mass and try again."
Replies (18)
Message 2 of 19
Create Mass Floors.
Message 3 of 19
huick2
Yes, I already created the mass floor (see the attached image), but still can't run the energy analysis
Message 4 of 19
ennujozlagam
https://forums.autodesk.com/t5/revit-architecture-forum/energy-analysis-won-t-run/td-p/8021006
Message 5 of 19
Post your file here.
Message 6 of 19
Try these:
1. Choose Conceptual Mass and Building Elements even though you only have Mass.
2. Choose Conceptual Mass only > Create Energy Model > Generate
Message 7 of 19
huick2
Thanks in advance
Message 8 of 19
huick2
I just want to sim the mass instead of the building elements.
Because building elements cannot apply the detail model parameter in energy setting dialog box.
Message 9 of 19
huick2
I think this is a different case because I just want to run a energy analysis of conceptual mass model. Not building element.
Message 10 of 19
Then use the option 2 I posted above.  It works as shown by the analysis result screenshot.
Message 11 of 19
Works Fine. Conceptual and Building Elements.
Message 12 of 19
huick2
So means revit cannot run the report by itself? Must be generate the report by insight?
Message 13 of 19
huick2
Message 14 of 19
Correct.
Message 15 of 19
huick2
Many thanks.
But is it normal, or it's a bug of revit😅
Message 16 of 19
@huick2 wrote:
Many thanks.
It is by Design.  You create a model in Revit, generate an energy model from it, and push it to Insight to run analysis.
Message 17 of 19
huick2
But why the system analysis cant apply in  "Use conceptual mass" ?
I searched the relevant tutorial video on internet and those video showing this function is OK. (Say 2014 version)
Message 18 of 19
Use Conceptual Masses: This mode is used with legacy workflows. This mode is provided only to support older models. Some advanced energy settings relate only to these legacy modes; those settings are unavailable when the mode is set to Use Conceptual Masses and Building Elements. See Create the Energy Model: Massing.
Help | Energy Settings | Autodesk
Message 19 of 19
huick2
Many thanks for the explanation.
Is it possible to change the Revit 2020 to legacy mode?
