I've been trying to do the energy analysis on my model (by using my friend's pc since she has the complete 2021 version of the software and mine was crashing at the very first stage; I have Revit 2019 educational) but it fails giving me the error "an unrecoverable internal error has occurred" and I can't seem to find the reason. I tried to move the N-W-E-S coordinates to 0,0, by following the guide provided by Autodesk, but it didn't help.
Can you tell me how to fix it? It's really important and urgent for my Master thesis.
Thanks in advance
P.S. I've already tried with the Insight forum but I didn't get any answer back and since I'm getting desperate I thought of trying also here
Solved by RDAOU. Go to Solution.
@Anonymous
Thank you for your help!
1) I hope it's the right information:
2) Yes, I have. Unfortunately on the 2019 model (student version) it doesn't go through:
and on the 2021 (on my friend's laptop) it gives me the unrecoverable error mentioned above.
3) The base point goes from here:
to here:
I've attached both models in zip files.
Thanks again
@Anonymous
Both you and your friend need to install latest updates...below is a list of all the updates for 2019 and 2021
Released Revit 2019 Updates & Add-ins | Revit Products | Autodesk Knowledge Network
Autodesk Revit 2021 Product Updates | Revit Products | Autodesk Knowledge Network
You can download them from Account Management or by clicking on the relevant release in the tables of the above links
Thanks again, I tried that too but my version wouldn’t change. I’ll try again. Is it compatible with the student version, too?
So, is this the main problem? If I manage to update the software will I be able to run the analysis? Or is there some other issue with my model?
Thank you so much
@Anonymous
Yes you should be able to get updates and hotfix on educational license
Nothing wrong with your model...the model you sent already had and Energy Model. I deleted it and recreated a new one and I didn't receive any error. Also Accessed the Model on Insight and an Analysis was generated without issues
@Anonymous
Here is a direct download link of the updates in Chronological order
https://up.autodesk.com/2019/RVT/9CA05B9A-1904-0510-A1B4-FFF7A680FE55/Autodesk_Revit_2019_1.exe
https://up.autodesk.com/2019/RVT/9CA05B9A-1908-0510-A1B4-FFF7A680FE55/Autodesk_Revit_2019_2_1.exe
https://up.autodesk.com/2019/RVT/9CA05B9A-1909-0510-A1B4-FFF7A680FE55/Autodesk_Revit_2019_2_2.exe
https://up.autodesk.com/2019/RVT/9CA05B9A-1910-0510-A1B4-FFF7A680FE55/Revit_2019_2_3.exe
