ENDPOINT of [Category Name]
denisyukJ
Message 1 of 10
denisyukJ
Can someone give me a hint what is that? Is it hidden geomtery or what?
I checked several times and haven't found any hidden lines my family file.
Replies (9)
Message 2 of 10
rxi.gg
Do you have DWGs imported?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 10
denisyukJ
Yes, but I deleted imported elements.
Message 4 of 10
rxi.gg
It seems a CAD file in the 3d view
Message 5 of 10
denisyukJ
No this is a sketch based on DWG file. Do you suppose this ENDPOINT is a part of DWG?
Message 6 of 10
rxi.gg
Can you share the family to check? The 3d model is  a DWG file?
Message 7 of 10
denisyukJ
@rxi.gg,
File in attached. I have simplified the geometry, but those lines still on its places.
Message 8 of 10
That is a ref plane.  If you don't want to snap to it in project, set it to Not a reference.
Message 9 of 10
rxi.gg
Try to insert the family in a new project because it worked well for me
Message 10 of 10
denisyukJ
Thank both of you!
