Enabling To/From Room Calculation Point for Non-Door Family
miajpilgrim
miajpilgrim
I have a revit family with Type 'Security Device' to represent a keycard scanner.
Because this devise is placed in one room, but gives access to another, I'd like to have the Room Calculation Point support a From Room and a To Room the same way it would for a Door Type Family.
Is this possible?
ridantuo
Room Calculation Point?
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-7CA9496D-205E-4838-A669-37C1DA7DEB67
and
https://www.youtube.com/watch?v=D2NiJoWTPwc
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
miajpilgrim
The video you have linked shows the To Room / From Room functionality. But that functionality does not appear to be available unless I use the Door Family Type.
What I need is to be able to have that functionality for a different family type such as Security Devices
ridantuo
I think you can get it automated in Dynamo. Plenty of manual ways to do it.
But seems slightly unnecessary as it sounds like mostly the other info is crucial which is the To Room. You swipe a keycard (etc) that gives access to one "area" right?
I think I was once playing around with a similar issue with a door like family that didn't need to be a door but needed the parameter. But to get it to show in a schedule was unnecessary challenging I decided to go with a door family instead as it was similar to a door. Security Device I wouldn't shove into a door category tho' 😄
