Enable to create form element
siwar.bouaoun
siwar.bouaoun
I have created an in place mass then reference polylines and the triangles are model polygons
When I have clicked create form this error appeared
Did you actually select something to make a form from?
...shouldn't be that difficult.
siwar.bouaoun
Yes I have selected The line and the triangles
Are you trying to do this? If so, your Triangle is not drawn on the correct workplane.  Tab on the Ref. Point to find a different workplane to draw your triangle on.
constantin.stroescu
Are you sure you have drawn the Profile on the Normal Plan to the curve defined by the Reference Plane?
Constantin Stroescu
