Enable and disable showing a Text label on family
danezeq
Message 1 of 22
danezeq
Hey
I have a Tag with 3 text labels:
1.  text label which always show and display the text value of the parameter
2 text label that should present a text, and would show only if the text value of the third parameter is not empty
3. text label that will show it's text value, and in some cases that value will be empty, so i want to hide 3 and 2.
as for 3, it's simple. but what about 2? How can i hide that text label? (without adding another yes/no parameter that will result more work for the user)
Replies (21)
Message 21 of 22
martijn_pater
You dont need those formula's, only the ones in the tag labels. That is just a way to return a default value, probably shouldnt have put those in there.
Message 22 of 22
danezeq
Finnaly, i did it thank to you.  many thanks!!!
