Embedded Text Electrical
I'm trying to modify my electrical outlet family. I want it to show the "GFI" text as a instance parameter that I can turn on and off. I would like to create the text show it will readable from every wall.
I tried creating it as model text but, when I put it on the top wall the text is upside down.
Also, I wasn't sure how to make the text a "yes/no" parameter. I didn't see that option in the menu.
Is this possible?
ennujozlagam
@Anonymous hello, post your family and see what we can do. thanks
The GFI tag turns off in Properties under Other. Which is great. But I still can't get the model text to be readable from all walls.
thanks
ennujozlagam
@Anonymous hello, sent already to your email add the screencast video. i'm not sure if this is you wanted it to be. hope it helps thanks
