Elevetion Symbol disappeared
Message 1 of 8
Hey,
I was trying to change level height and all of a sudden i found iut that my elevetions are gone from all of the views ( 3D,Plan views and elevetions.)
what can i do to find them?
I tried to make my CROP REGION huge to see if its in there, and its not..
* in Visibility Graphics, the "Level" checkbox is checked.
where can it be????
thanks..
Replies (7)
Message 2 of 8
You mean spot elevations or levels, it would be nice if you went up an image
Message 3 of 8
How did you change them? Uncrop the view. Create a new 3d view and you should see the levels, then select them, right click and maximize 3d extent.
Message 4 of 8
Hey,
I mean Levels. Can't seem to see them not in the Elevetions nor in the 3D:
Thank you for your answer
Message 5 of 8
RobDraw
Make a new 3D view and uncheck all categories in the V/G except for levels. If they show up, turn on walls to make sure that they are within the building.
Rob
Message 6 of 8
Jamhmer_Oc
Another option, in an elevation create a level, select the created level and make anticlick, now Select All Instances > In Entire Project.
Selected all, again anticlick and Maximize 3D extension.
Check if it is hidden, activating the option.
Jamhmer Oc
Message 7 of 8
RobDraw
What's an anticlick and how do you make it?
Rob
Message 8 of 8
Right-click.
