ELEVATIONS tab, Elevation Marks are missing?
Message 1 of 8
Hi ,
I am beginner in using Revit.
I noticed that I don't have (ELEVATIONS) tab and also (elevation icon). See the picture. Also (Elevation Marks) in the window view are not exist.
How can I regain all these?
thanks
Jaf
Replies (7)
Message 2 of 8
Alfredo_Medina
  • The Level tool is not available because the current view is a floor plan. The level tool is available only from elevations or sections views.
  • Elevation views do not exist in the project browser because no elevation has been created yet and/or because this project was started without a basic template that includes some default views. If you create at least one elevation, the "Elevations" folder of the Project Browser will be created. To create a new elevation use View > Elevations.
Message 3 of 8
 Thanks for your fast response.
I tried your idea(view ---> Elevation) but no positive result. But in a sample drawing , (Elevations tab) is exist.
I tried to use a template, but what I found, that I don't have any template and library. See the attach picture (as example).
Is that to do with mistakes in installation process? or there are othere reasons?
thanks
Jaf
Message 4 of 8
Alfredo_Medina
Probably, the installation did not finish properly, and you don't have templates?
But I don't understand why using View > Elevation gives "no positive result" to create new elevations.
The lack of templates can be fixed by finding the files and putting them in the correct folders.
Message 5 of 8
Thank you for your responses. I solved it. It was mistakes in the installation.
Message 6 of 8
hi,
good day, im having the same exact problem that you have, and canyou help me out with this? how did to solve it?
Thanks.
Karl
Message 7 of 8
Hey, I had the same problem and I still didn't find the RIGHT answer, but you can solve it like I did by chance, go to Open => File examples (or sth like this sorry I have french version) and from the list you chose for example 'Arch Link Model'.
This file has already everything in place including elevation marks etc., it may be a better way to start with. Maybe it's possible to write it down as a template.
Good luck,
M.
Message 8 of 8
 please help i have no templets in ravit 2011 but the problem is how to include templates in ravit 2011
