Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Elevation view lighting
5 REPLIES 5
yes_and_no
263 Views, 5 Replies
Guys, we use this for elevation view, attached. Notice the bottom view has cabinetry much darker, compare to the birch wood finish of the door above.
  • I tried all available options of the view setting, almost no result, to make the bottom view brighter.
  • Attached here you can see I can do that with Photoshop, however, of course.
     So, is there a way to increase brightness in interior space, without placing light fixtures or changing object materials ? Yes, I have Googled this (to some Googleists here), without result.
    • Thx.
5 REPLIES 5
in reply to: yes_and_no
Have you compared the Graphic Display Options of the 2 Views?
mhiserZFHXS
Those don't even look like the same material. The part of the door that's in shadow in the first image looks very different from the cabinetry.
On a separate note, there is an option for consistent color (no shadows) with material textures that's on the public roadmap, so that should be coming soon, though that doesn't help you now.
The door panel is partially open so the light hits it at a different angle, hence the less contrasting colors.
yes_and_no
in reply to: barthbradley
I duplicated the view template and making changes. There are a few sliders, light, shadow, env.light and graphic exposure...but none makes the differences, or perhaps so little that my eyes couldn't see.
