Elevation view is showing a secion - how to fix?
woodstim
woodstim
One of my elevations (South) is showing a section. How do I fix this?
When I turn on crop view, crop region etc. the floorplan is inside all of these.
I think I have however deleted my original view planes you get when starting a  new project. If so, and this is the reason, how do I re-instate them? Other than that, I cant see why a section is showing and not the elevation.
Thanks for your help.
Ilic.Andrej
If you don't want the elevations to show sections, this is what you do:
(you can also create a view template so that all elevations have the same settings....)
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
aRcHiTeCt.JM
... or you can just go to the view and with right click opens the dialog and then choose hide elements:
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
