Ok, this may be a "newbie" question, but I'm baffled. I only have one level to my drawing (level 2 is there, but empty) and I am trying to insert the interior elevation tag on level 1, but it inserts on level 2 instead. It won't work on level 1. I get the following warning:
"None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I DID check Visibility settings, and every box is checked. This is a VERY basic plan for an ADA toilet room at 1/4" scale, and I have no idea what I'm supposed to be checking for! This seems like it should be a really simple fix, but I'm baffled.
