Elevation tag won't insert on level 1, but inserts on level 2 instead
m.monhollen
m.monhollen
Ok, this may be a "newbie" question, but I'm baffled.  I only have one level to my drawing (level 2 is there, but empty) and I am trying to insert the interior elevation tag on level 1, but it inserts on level 2 instead.  It won't work on level 1. I get the following warning:
"None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I DID check Visibility settings, and every box is checked. This is a VERY basic plan for an ADA toilet room at 1/4" scale, and I have no idea what I'm supposed to be checking for!  This seems like it should be a really simple fix, but I'm baffled.
There could be a thousand reasons "it's" not showing, but it usually boils down to 33.  Keep this cheat sheet handy to reference:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
SteveKStafford
Visibility/Graphics > Annotation Categories > Elevations checked?
What discipline is the floor plan view assigned to?
Same for the elevation view?
Elevation view parameter "Hide at scales coarser than" - what is it set to? Is the floor plan view set to a "coarser" scale than that?
Is this project using your office template or a stock Revit template?
Steve Stafford
m.monhollen
Your solution was spot on.  The discipline was wrong.  Thanks!
m.monhollen
Thanks! I knew most of these... but there were a few I hadn't known before
Like #21?
