Elevation Mark Body is showing, but the Elevation Mark Pointers are not
- Mute
- Permalink
- Report
The text within our elevation markers was too big for our sheet naming convention, so I opened the Mark Body family and changed the text size. There was no problem for the interior elevations, but our exterior elevations went haywire!
My understanding of the family organization:
1) Elevation System Family (Interior was unaffected, Building is broken)
2) Elevation "Mark Body" family for exterior/building elevations (interior has a different shape) (this family has a label referencing which sheet the view is placed on)
3) Elevation "Mark Pointer" nested within the "Mark Body" (this family has a label referencing which view number it is on the sheet)
Symptoms:
- all interior elevations (views, bodies, pointers) were unaffected
- all Mark Body for our exterior elevations are showing
- all existing Mark Pointers disappeared, taking referencing labels with it
- all existing exterior elevation views are still in the model and placed on sheets
- placing a new building elevation acts like normal (Mark Pointers, references and all)
- attempting to delete the Mark Bodies will provide a warning that "View X will be deleted"
- can place a new view in the same direction (if the "hidden view" is facing south I can place another view hosted to the same Mark Body facing south. Deleting the Mark Body will provide the same error that two views are about to be deleted)
Attempted solutions:
check visibilty graphics/hidden objects- the problem only affects building elevations created prior to the editcheck phasing, discipline and annotation cropcopying the elevation families from another projectchecking the nested families and their visibility parametersduplicating views- creates another Mark Body with an associated view but without a pointercopying Mark Bodies- creates a blank Mark Body without a view attachedchanging the affected elevation markers to Interior Elevations- no change, problem persistsrestarting Revit- this doesn't appear to be a graphical glitch
The attached image shows a building elevation created AFTER the edit, followed by a preexisting building elevation (broken, but I promise it has a view associated with it), followed by an interior elevation created after the edit (no problems here).
I can create new elevations that reference the existing views, but there are too many views and too many people in the office that wouldn't know how it works. This workaround would create more problems than it would solve.
I have a feeling that I may have to recreate each and every building elevation, annotations/view ranges and all. I would rather not because there are several buildings and several elevations per building within this project, but if it's the only way...
Any help is appreciated! Thanks,
J
