Elevation Detail Items in families displayed only in perpendicular Sections/Elevations
dimitris9GXW2
Message 1 of 10
dimitris9GXW2
Dear Revit users,
I have placed some detail items in some tree families. The question concerns the detail items placed in Front/Back, Left/Right views in the family. When the Section is created parallel to the X or to the Y axis (S2- im.1) then the elevation detail items are displayed properly (im. 2). When the section is created at random angle (S5 - im.1) then the elevation detail items are not displayed (im. 3). Is there a setting or some other way to resolve that? In order for the detail items to be displayed at any angle section?
image 1
image 2
image 3
Replies (9)
Message 2 of 10
rxi.gg
have you tried a 3d text? i think that the way you do it only can show in x and y axis
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 10
dimitris9GXW2
Hello and thanks for the answer. The question is not about the text tags it is about the representation of the 2d detail elements. In the bottom picture the 2d detail elements are not displayed.
Message 4 of 10
rxi.gg
I understand, but the 2d of the trees work like the text. You can only see them in X and Y axis
Message 5 of 10
dimitris9GXW2
I see but I don't get how the 3d text is going to help me with the Cad file. Am I able to place a 2d drawing as a model text?
Message 6 of 10
dimitris9GXW2
So, to wrap up. there is no option for what I'm looking for?
Message 7 of 10
You cannot use a detail component for that. Draw the tree elevation using model line instead.
Message 8 of 10
dimitris9GXW2
I did it with an imported Cad, but it has hatches inside. How would that work? If I convert the imported lines to lines would that be sufficient for the outline? And obviously the hatch will never show in a non perpendicular section view, is that right?
Message 9 of 10
Detail Items are View Specific. They are only visible in views parallel to the detail plane.
Message 10 of 10
If you want to use an imported cad, then don't import it in a detail family, import it directly on an elevation of the family, in another model family if you want to nest it.
