- Mute
- Permalink
- Report
I have a problem with the line view and printing from Elevation and Section views.
I want all the lines to look exactly like in a plan view (black, normal width), because now the section and elevation views show very thin lines although I already tried to change manually the thickness of the lines for curtain wall elements and floor to see if something would change, but it didn't change anything.
When printing out the views on paper all the lines have some kind of red dotted lines over all the black lines and I can't explain why.
Here on the example picture you can see the difference between plan line types and section line types. In the section views also the dimensions show in a normal width and black, so it should be connected somehow to the template, but I can't find the problem.
