Elements not visible in V-Ray Rendering in Revit 2020
jakub.dorobek
Observer Observer
jakub.dorobek
Observer
Observer
I have a problem with rendering and I hope you could help me! I have made a Revit Model using structural elements such as columns, beams and connections between them. When I render a 3D View using the Revit Rendering they are visible and I can change their appearance. However, when I use V-Ray Rendering none of them is visible in a final image, like there were not there. (The detail level in the View is set as Fine, and everything is set visible in Visibility/Graphics)
Kind Regards
Huh? You mean it's a fully Rendered scene?  No "blank" spots?
jakub.dorobek
Observer
Observer
Yes, it is fully rendered scene with no structural elements, no contours, nothing, blank space instead
pearlofsadness
same thing happened to mine too. Any solution yet? 😞
