Elements disappeared from site plan
vmoustos
vmoustos
Hi ! Model disappeared from Site Plan how i fix this ?
ennujozlagam
try to activate your bulb icon it could be hidden in the view or go to properties > uncheck extends and see if helps. thanks
vmoustos
Thank you for answering...but not working, still empty site plan
RDAOU
@vmoustos
There are more than 50 reasons thing can disappear in a view
  1. Phasing and/or Phase Filters
  2. View Range
  3. Model is a Link or Part of a Link which was unloaded
  4. Model elements are in a Design option which is not primary
  5. Visibility Graphics (one or all model elements unchecked)
  6. The view is set to not display Model
Either share your model for someone to check or go through the above and the following list of most likely reasons
