Element Override vs View Template - not matching
cbt990
cbt990
When I override the graphics of the window I am able to reduce the weight of cut lines to 1:
When I try this using the View Template to make the same change, it doesn't work:
Revit is amazing
Some other override is in place.
Maybe a Phase Filter GO?   Set Phase Filter to "Show Complete".
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
hmunsell
overrides have Hierarchy's. like @barthbradley said, check for other overrides.  here's something to help....
Howard Munsell
cbt990
Haven't been able to figure this one out. Posting the file with my view template if anybody wishes to take a look.
Thanks.
Revit is amazing
is this what you are trying to do?
