When I place an outlet receptacle for some reason it hosts itself to behind the finish face of the wall. It also seems to be inconsistent. What options are there to fix this?
Is that a family that comes with Revit?
this happens sometimes... pay attention when placing and use the TAB key to cycle thru the placement options. once it selects the surface of the wall you may need to click on the space bar to flip the symbol.
Howard Munsell
Looks like two of the outlets are correct and one is not. Are they the same family? If not, post the family that isn't cooperating.
Better yet -- post the Project (RVT).
