Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Editing a split face
Message 1 of 13
Good morning
I have used the split face command to add some sailor courses and marble faces to a brick wall. Everything is working well......
I need to revise one of the outlines for the sailor course. I cannot figure out how to get back to the outline of the sailor course to change it.
Wiley
Replies (12)
Message 2 of 13
Alfredo_Medina
You need to select the face, then the ribbon will switch to the Modify Split Face tab. There, find the Edit boundary tool. If you have difficulties selecting exactly the face you need, hit the tab key until you see the "Split face: face region.." notification in the status bar.
Alfredo Medina
[email protected]
Message 3 of 13
Thanks Alfredo,
I got it now.
Message 4 of 13
That did not work for me and i'm having the same problem right now. When i edit the boundary, ALL my split face lines disappear and it only highlights the outer boundary. It doesn't let me select the split face when i select a range and then filter.
Message 5 of 13
You need to TAB until only the Split Face line is highlighted. Otherwise you edit the boundary of the entire element.
Message 6 of 13
Are yours faces that have been split, or are they sweeps/reveals?
Message 7 of 13
Had to cross-select on a soffit and then filter only the split face in order top be able to then edit it.  Not such a problem on walls for some reason.
Message 8 of 13
Try to select in 3D instead of plans
Message 9 of 13
I think this is the easyies way, ty for the advice
Message 10 of 13
dkingson
The ribbon only allowed editing the boundry - not the pattern
Message 11 of 13
mmartinez6HFXW
Observer
Observer
Reopening this old thread because I was having a similar issue and wasn't able to select the split element to edit the boundary, hoping that this will help others too if they come here..
My split face was done in a workset that wasn't visible.
This allows to still show the different patterns, but won't allow to select the split element.
So either check for hidden elements in your views or set all your worksets to "show" in the view you want to work (if you're working in a shared model)
Message 12 of 13
Trinh_TH
2 Ways to select Split face:
 - Zoom out until Hatch display changes into solid. Then Tab to select Split face.
 - Use Range select and Filter to get the Split face.
Message 13 of 13
c.walshBCL6Z
Community Visitor
Community Visitor
Thank you for this answer! I was going around in circles, hadn't thought about worksets, and this solved it!
