Edit Tooltips in Shared Parameter
armiin_hodzic
armiin_hodzic
Hi, i was wondering is it possible to add tooltips to shared parameter after creating it?
RDAOU
@armiin_hodzic
Once the shared parameter is created, they are not editable through that button. You need to edit the discription in the SharedParameters.txt file (Use Notepad++ or excel)
Careful when editing that in order not to mess up the formating
mari.shimode
Hi @armiin_hodzic, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
