EDIT PREDETERMINED NAMES PRINTING SHEETS IN PDF
When I print the sheets of a project in PDF (with adobe pdf) in separate files, the predetermined name is the conbination of *the file name*(in red) + sheet + *sheet name in the project* (in green).
I want to know how can I edit this configuration to remove the "sheet" part, so I dont have to erase it when printing each plan.
Also I want to know if there is a way to print all the sheets at the same time (in separate pdf files), without having to be accepting the printing of each one.
*I add a screenshot of the situation
MostafaElashmawy
Regarding your first question,there is no current built in method to control the naming methodology. However, you can use a separate app or program to batch rename the files after print , e.g. "ReNamer"
Regarding the second question,  follow below screenshot, click  Properties of adobe pdf , then instead of "prompt for Adobe PDF file name" browse your printing location and un-check the box beside "View Adobe PDF result".
Mostafa Elashmawy
Thank you Mostafa
