Edit parameter unit format greyout
XXalessio.amodioXX
Message 1 of 18
XXalessio.amodioXX
Hi all,
I have a truble in changing family edit parameter unit format. Just for the records It is an anchor family.
Some ideas?
Replies (17)
Message 2 of 18
Hy
In Revit, all the units are controlled globally.
How to change the units in Revit
Message 3 of 18
Is Diameter a Length parameter? I bet it is not.
Message 4 of 18
@Anonymous FYI:
Message 5 of 18
@ToanDN
Of course, it's a length parameter.
However, it is not controlled with "Length", but with "Bar Diameter" (Discipline Structural).
@barthbradley
Thanks, man. I forgot about that.
Obviously this does not apply to all parameters.
Message 6 of 18
Don't use that Diameter.  Add a calculated value parameter = 2*Radius and you can format the units.
Message 7 of 18
XXalessio.amodioXX
I hope i can make myself clearer with the video. I would like to tag the anchor diameter without decimal places.
Message 8 of 18
XXalessio.amodioXX
Hi
Unfortunatelly is not working.
Message 9 of 18
For the last time: This is not possible with all parameters.
But you can control it through the project units.
Message 10 of 18
Yeah the Diameter is clearly just a text parameter, hence no formatting.  The radius, even though listed as a one of the anchors' available parameters, does not actually appear for the anchors.  I have no solutions as this time.
You could use Comments field to type in the Diameter value as you see fit, then use that for the label.
Message 11 of 18
I don't believe what you show has anything to do with his.  They are two different things.  Try an anchor and an anchor tag.  And units format should be available for all parameters with units (Length, Area, Volume, etc...).
Message 12 of 18
@ToanDN Let's have a look.
C
D
D
Message 13 of 18
Again, Diameter and Length of Anchors are text. They list different configurations of the anchors coming in from the Advance Steel database. They are not the Length parameter, don't let the names fool you.
Message 14 of 18
I can only test the annotation family.
I have no anchor families with me.
If your statement is correct, where is the problem?
Then you can write "3 tomatoes" as length in the properties. Without zeros behind it.
Message 15 of 18
The problem is you can't write to Diameter and Length of an anchor. They are readonly, coming from a database.
Message 16 of 18
XXalessio.amodioXX
Problem is that radius parameter not working for anchoring.
You can do whatever with the parameter but it WILL NOT appear in TAG.
Message 17 of 18
XXalessio.amodioXX
Hi, I do believe it is the best solution, but not parametric one because I have to type manually anchor bolt dimension.
Message 18 of 18
Theoretically you can open the database in Advance Steel and modify the Diameter list, then reload it back in Revit.
