Edit-in place sweep problem
I am having trouble with edit-in-place sweep. I drew sweep path and when I am in edit-in-place model it seems fine, but as soon as I click checkmark and get to my floor plan I get a weird circle from the sweep. Please see attached. What would be the reason that sweep is doing that? It is just a line that is showing up only in my plan view but as soon as I get to the edit-in-place family it disappears. Thanks!
The path is the problem.  Draw it in 3D view and pick edges that are contiguous to each other.  Also, you can align and lock a model line to the "path" and pick that Model Line instead of wall geometry when you "pick path".
ennujozlagam
it could be the path lines does not intersect properly, try @barthbradley suggestion. thanks
I have tried doing that but unfortunately, I still get those circles.
let's take a look at the file. Post it. You may need to zip it first.
