Edit flush panel garage door
laurenMBVM7
Message 1 of 26
laurenMBVM7
I opened the flush panel garage hoping to add windows to the face of the panels, when I add the frame and glass, they are not hosting to the face of the flush panel but more center of the frame of the garage door. On the ref level on the garage door, it looks correct, just not rendering right. How can I fix this?
Replies (25)
Message 2 of 26
Post the family here so we can take a look at it.
Message 3 of 26
laurenMBVM7
here are the screenshots
Message 4 of 26
I saw those. Want I want to see is the RFA. Post the RFA here as an "Attachment" to a reply post.
Message 5 of 26
laurenMBVM7
got it, thanks
Message 6 of 26
laurenMBVM7
here is the rfa, thanks
Message 7 of 26
I would create a panel with windows and swap out your top panel out for this panel with windows.
Message 8 of 26
laurenMBVM7
smart! do you know if the panel is in the library to edit or did you just draw a new panel?
Message 9 of 26
laurenMBVM7
Message 10 of 26
laurenMBVM7
got it, thanks!!
Message 11 of 26
Here's a head start for you.
See attached.
Windows are fully parametric.
Message 12 of 26
laurenMBVM7
I made a new panel and still floats off the front, what am I doing wrong?
Message 13 of 26
I don't see anything wrong with it.  I did correct one issue though. See attached revised RFA.
Message 14 of 26
Actually, you have other issues.  The panel and the windows are not constrained properly.  Open and exam the family I did for you earlier (message #11).
Message 15 of 26
laurenMBVM7
How can I make the panel have 4 windows for the 16' version?
Message 16 of 26
laurenMBVM7
how can I edit the 16' panel to have 4 windows?
Message 17 of 26
laurenMBVM7
the panel doesn't want to expand and I made the 16' panel, just can't insert it correctly
Message 18 of 26
Like I said above, use the family I originally sent you that is in message number 11.
Message 19 of 26
laurenMBVM7
I don't understand how to edit the 16' door as when I open it to edit the 8' door appears. I need 2 windows on the 8' and 4 on the 16'. Can you help me understand how to edit one part of the family?
Message 20 of 26
I would suggest placing two 8'-0" 2-window Panels next to each other or creating another panel with 4 windows.  You could get there with one panel family that would create windows, but it would require a great deal of work using arrays and formulas. Is it really that necessary?  You really only need 2 Families. One for an 8'-0" Windowed Panel and one for a 16'-0 Windowed Panel.  Right?
