edit concrete beam shape in section
Can someone give idea how can I edit shape as attached in image
Thanks in advance
BEE_Design
Hi vic1z,
This looks like a cranked beam. If you're not doing anything like structural analysis, then you could build your own beam family. Start with a generic model family and create sweep. From my experience cranked beams are scheduled as one element so you can model the whole beam as one generic model. Add parameters where necessary to change dimensions etc.
Good luck!
SY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
RDAOU
Hey @Anonymous
Did the above reply from @BEE_Design clear the doubts you had and/or help you sort out the issue of your OP? If yes please mark with "Accept as Solution"
if not, let us know so we may try and find a solution for ur question : o) ... If u solved it already, you might also want to share your solution and close out the thread
Thank you, for the question and sharing information.
