Eccentric foundation wall joining issue
XXalessio.amodioXX
Message 1 of 12
XXalessio.amodioXX
Hi all
I do have problem in joining properly foundation wall with eccentricity.
If the eccentricity is maximum i cannot join wall foundation.
What is the best way to model it?
Replies (11)
Message 2 of 12
Alan.johnson1970
Can you attach your model?
AJ.
Message 3 of 12
Trying Unjoining.  Then resize and Join.
Message 4 of 12
You can always grip stretch the foundation farther out and use align tool.
Message 5 of 12
XXalessio.amodioXX
Hi
Unfortunatelly this is not working. I enclose the rvt. file
Message 6 of 12
XXalessio.amodioXX
Sure.
Message 7 of 12
XXalessio.amodioXX
Hi all,
Do you have any solutions?
Message 8 of 12
Alan.johnson1970
The only way I could get it to look like what i think you want was to change to a Retaining Footing and set the toe to '0'
AJ.
Message 9 of 12
I had no problem with your footing. All you need to do is disallow automatic wall join and join manually (via Join Geometry).
Message 10 of 12
susanaapolayo
Thanks @barthbradley
Message 11 of 12
sophiaVETFT
Fixes / Work arounds no longer work in 2020.
Message 12 of 12
XXalessio.amodioXX
Hi.
I find out that better solution is to model them as Structural Floor and add a parameter ''Foundation'' in Type Comments or similar in order to better sort and/or schedule them.
