Easiest way to uncheck 'Shared' in nested families.
5 REPLIES 5
amirCKP
2405 Views, 5 Replies
Hi guys,
I had compile a few of family in a project and now I having problem with the nested shared family.
How can I uncheck 'Shared' in all the families that i had compile in easy way? is there any plug-in that can do that?
The way that i know is edit the family, go to the sub family in the family, then uncheck the 'shared', load back to the family, and load to the project.
It is okay if we have 1 family. what if there are a ton of family, it will be forever to do it. haha
Thank you
Labels (3)
5 REPLIES 5
RDAOU
in reply to: amirCKP
@amirCKP
No there isn't an easy way...
More bad news, you cannot simply open the nested child, uncheck and load back in...It is not possible to nest/load a non-shared version of a family when there is already a shared version of it in the Host
amirCKP
in reply to: RDAOU
yes that the baddest thing to know about it. haha.
anyway thanks for replying my question.
Martijn.Pater
I think you would always have to save the non-shared version under a different name, then load it back in and switch it. Or just leave it as shared family, no harm in that aswell probably...
amirCKP
in reply to: Martijn.Pater
Thats a good idea. And i think that is the easiest way to do it right.
Thank you bro!
RDAOU
@amirCKP
It depends on your understanding of EASY...simply swapping a shared nested child with a non-shared is not possible regardless if the name is same or different.
You will need to nest the non-shared family, lock and constrain it and re-associate its parameters. Simply a PAIN
