Dynamo "Sheet" only sees "Views"
craig
craig
I've followed a YouTube tutorial to create a dynamo script that draws a line of a chosen weight over the visible crop boundary for all views on a given sheet. The problem is, the "Sheet" only sees views in the project in its drop down selector rather than sheets. What the flip!?
Go into the View itself.
L.Maas
Something like this
Of course there needs to be sheets available in the project Dynamo is attached to.
Louis
Please mention Revit version, especially when uploading Revit files.
craig
What do you mean by "go into the view"? I have a 30 sheet project with hundreds of views
craig
I don't know how to make my programming look exactly like yours. Additionally, how do you tell it what line weight to make it?
RLY_15
It looks different because of version differences. There was a visuals overhaul between the Dynamo versions packed into Revit 2022 and 2023 (and more functionality, of course).
The ViewSection.OverrideCropVersion2 node in your original screenshot is what defines the line weight. L.Maas was just showing you how to collect all of the Sheets (using Categories + All Elements of Category), so that you could feed the list into the script you had originally provided.
craig
Ok. So I would need to combine both my programming and his somehow!?
