Dynamo question - Get host elements ID
Radu_IB
Radu_IB
Dynamo Newbie here - trying to get the name of the wall (type) transferred as an instance in the door family. Basically want to get the material of the host element. Could it be that the Dynamo nodes do not recognize type parameters?
Any other best way to copy parameters from one family to another?
Thanks in advance for the help
se.ha
Hallo @Radu_IB,
did I understand this correctly? Select door, get host (wall), get host name, write name in door parameter?
You can use FamilyType.Name or the GetParameterValueByName from the rythm-package to get type or instance parameters.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Radu_IB
Thanks @se.ha
Worked like a charm for wall parts. Still having a problem finding the curtain walls for some reason.
Any suggestions on how to improve the search?
Thank you & best,
Radu
se.ha
Hi @Radu_IB,
and you´re certain, your curtain walls contain values in the parameter "Art_der_Wandkonstruktion"?
se.ha
Radu_IB
Hi @se.ha
se.ha
It´s difficult to say without the file and the dynamo script but you screenshot shows an instance parameter. Can you make sure that every instance of this walltype has the same value?
se.ha
